- Jul 7, 2013
as ATM said, you want airFLOW. A.k.a you want a "breeze" over the components. Get a Hyper 212 Evo if your case supports that size cooler, and put one fan up front and another on the back. If your case has no support for fan mounting in these positions, I'd recommend getting a case like the DIYPC Solo-T1-BK. It's $30, nothing special, but will support the Evo, or any other cooler 160mm in height or less (if you want to use the fan mounts on the side panel then make it about 135mm or less) and has front and rear 120mm fan mounts. Plus the fans come pre-installed for the front and rear. The side mounts (there's two) support 120mm each, but you have to buy the fans yourself and you'd need a fan controller.
