- Jun 5, 2009
I built my PC in 2008 and am in need to perform an upgrade. I plan on salvaging my GPU, PSU, case, optical drives and hard drives. This is what I have put together so far:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL8D-8GBXM
ASUS Z87-PLUS LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-4770K Haswell 3.5GHz LGA 1150 84W Desktop Processor Intel HD Graphics BX80646I74770K
Plextor M6e PX-AG256M6e PCI-E 256GB PCI-Express 2.0 x2 Internal Solid State Drive (SSD)
My needs:
- I'll only ever need a single GPU solution, never any Xfire or SLI
- I do mild overclocking. Basically whatever I can get with hearty airflow and little to no voltage increases.
- Aside from the PCI-E ssd, I have 7 SATA drives full of storage so I'll need those SATA ports.
- I'll be running x264 encoding, Plex server, Adobe Premier, light gaming
Basically I want to update my PC and consolidate/retire my file server so I only need one machine running to power my WMC and Plex setups. Right now my Q6600@3ghz might not be able to handle 3+ streams at the same time. It has been several years since I've built a PC so my questions are:
1. I want to take advantage of the RAM timings. I've never messed with UEFI bios before and I want to make sure that mobo is good and isn't overkill.
2. Should I stick with CAS8 1866 or should I do CAS7 1600? I want to know what would be best in a mild overclock situation.
3. Is Z87 a good chipset to go with these days?
Money isn't really an issue, but at this point I'm guessing I would need to drill down and find my best-bang-for-buck setup. Any other mobo suggestions for my needs would be welcomed.
My needs:
