- Feb 1, 2013
Good Afternoon!
I have some questions with liquid cooling and I thought what better place than somewhere they congregate. So here I am!
So I just recently bought a Thermaltake Bigwater 745 and it’s a pretty awesome little starter kit for the price I paid (Less than $100) and I noticed a few things between the reviews and looking at the package, there isn’t enough coolant to completely fill the system mostly but not to the high mark on the holding tank.
So with that what are some good inexpensive liquid that I could use? I read that I could use Distilled water or Anti-Freeze is that correct or someone blowing smoke?
Also I am kind of going with a blue theme with my case (Details on exactly each part are in my signature) so I was wonder what type of Tubing would be recommended?
The connectors on everything is some-type of fitting that screws down but doesn't really feel like its water tight so I was thinking until I buy some better fittings ( Also would like suggestions on which to buy) should I use some plumbers tape?
I would also like to take the reservoir out of the bottom of the case and have it in one of the many extra bays that I have so I can keep a better eye on the system.
I've also read that it’s hard to see the water moving once the system is setup so what is recommended to remedy that?
