I can't get either program to run. PCMark05 requires that the WM Encoder be installed, but at you said even falling back to the 32-bit encoder does nothing. As for AQ#, it seems that the x64 compatability issue is well-known.Deanzo said:I used X64 for just over a year, and AQ mark never worked for me.
And as for PC Mark05, the amount of time for zero results just did my head in..I tried the 32bit WM encoder but it never help me, but good luck and if you ever get it to work I'd love to know how.
El<(')>Maxi said:aaron have you tried running AQ3 in Compatability mode?
aaronjb said:Update: PCMark05 run completed, added and updated the PCMark05 hwbot post.
Deanzo said:Well I can see Im going to have to give PC05 another go, when I first installed vista 64 months ago this is a list of tests that failed in PC05, HDD - XP Startup, HDD - General Usage, Multithreaded Test 2 / Text Edit and Multithreaded Test 3 / HDD - Virus Scan.
Did you do anything other than install it and run the bench mark ?
El<(')>Maxi said:Read first post, complete steps as indicated, join Team
sno.lcn said:
