- Aug 11, 2002
- St. Louis, Mo. U.S.A.
Been seeing this mentioned alot where builds will have the OS on a Solid State Drive and then a SATA drive for storage. Pros? Cons?
It all depends on how you set it up. I set mine up so nothing gets installed on my OS drive. That way when I have to redo winders because of benching I don't lose all my programs
the other question is about installing programs...wont the system use both drives?
I've reinstalled twice and so far no issues with anything.
I just don't see how you can wipe out the Windows registry with a clean install and have it find programs that are on another disk that involve registry entries. Registry has to do with registration and that is done when the program is initially installed.
Well on other ssd now with complete clean install only thing that didn't work was battlefield 4. All other programs working like nothing happened
