I cant remember now but it was something I never heard before and wasnt listed in the cpu database but I really dont think thats the problem since I can set the multiplier really low and not up the fsb to even get in at a lower than stock speed.res0r9lm,do you have a link for doing the vio mod on this board?All I can find is some picture of doing it but nothing specific.That just may be the problem because If I have the fsb high enough to where I can windows to boot,like say at 137,the vid card is the first thing that gives me a bsod.Malakai said:what stepping cpu is it?
+3.32,my 5v is 5.08.I have a 500 watt psu.Thanks fot that link,Im off too work now so I will look at it tonight.res0r9lm said:what does mbm say your +3.3v is mines at 3.23v
Your vcore for your cpu you can but you cant adjust the vio.Starfox said:guys, can you change the voltage in the BIOS without
any modding? can i go from 1.75 to 1.80 without modding?
thanks
max you can set is +.100 anyhing higher and it reverts back to default voltageCaffinehog said:The AK31 will only go up to 1.85 Vcore by changes in the bios. The bios SAYS you can go up by a lot, but it will only allow 1.85. Kinda crappy, but oh well.
res0r9lm said:I have had my board up to 168 stable but thats all see will do stable w/ crucial ddr 2100
lubetek said:
168? the board only does 166 stock. did u get a different BIOS?
