For your information Bosco, the clocks listed in my sig are the clocks my systems run at 24/7/365. And they also are running BOINC too, either on Seti or Rosetta@Home. I don't list some benching clocks in my sig as those are unrealistic and not representative of their performance. If I did, my 980X would be in the high 5's for speed as it's been way past 5500 on LN2 with 1.6-1.7v vcore. And 200 watt heatload has been easily breached for 24/7 clocks since the first Intel Core 2 Quads. Believe what you want; but I for one take offense at you sneering at my heatsink reviews as I work my butt off at them and put what I think is a more appropriate heatload on them, unlike what Frostytech does. Hell, your high end Intel systems and AMD also have nominal listed TDPs of 125-140 watts, so a 150 watt heatload doesn't hardly even come close to the load on them even moderately overclocked.
And next time you call someone an idiot here Bosco, you will be getting a vacation from the forums, understand? That was a personal attack on me and anyone else that doesn't think a 200 watt heatload unreasonable. These forums don't tolerate people attacking others.
keny, the reason I haven't tested the Frio is that it was reviewed by Archer0915 already, so as far as I'm concerned I don't need to revisit it. Archer found it to be a good heatsink, but did have some potential ram slot interference problems for some boards, IIRC. And with Thermaltake, my results in the past with their cooling products has been spotty. I've had dogs from them (GORB) and I've had good ones (Big Typhoon).
