- Dec 14, 2010
What are your preferred methods of applying thermal compound/paste?
I've tried several different methods myself.
Tried the dab o'paste in the center and locking the heat sink down on top of it method, as so often recommended, but found that method not to be very efficient. In my case the thermal paste only covered about half of the CPU with this method.
Also tried spreading the compound with a glove or plastic bag over my finger, but found the compound was so sticky it just stuck to the glove/plastic bag and I couldn't get it to spread on the heatsink.
I've also been told that spreading it with a paper towel can work, but that can also leave behind fibers in the thermal paste and also seems to dry the paste out quicker, so not such a great method IMO, though it will work in a pinch.
Personally I prefer the method of spreading it on the CPU with a credit card or other flat semi-rigid device. I like to know that my CPU has full coverage before I set my HS down on it. I've found that this method can get me a nice even coating that is not too thick, and the excess ends up on the card, so you can then use the excess on a Northbridge or Southbridge chipset if you wish.
