- Jun 27, 2013
- Mesa, Arizona
I've been researching and reading for weeks now on what sort of cooler I'd like to upgrade to. Currently I'm running a 92mm Zalman tower that was purchased because my previous case design prevented me from having anything taller.
I've purchased a new case that allows me to run whatever size CPU cooler I want now, which is good because I'm wanting to get into overclocking the 8120. However, no matter how much I read, research or search for comparisons, I can't pull the trigger on the best decision. I'm not into custom water cooling loops yet so my choices are either big air coolers or closed loop coolers.
At the top of my air cooler list is the NH-D14. It's tried and true, quiet, and inexpensive. What I can't get past is that it's so massive and not very pleasing to look at (IMO). After measuring, I noticed it would be a very close fit, and would most likely also have to replace my vengeance ram as well.
The top of my CL cooler choices is the Thermaltake Water 2.0 pro. It would allow me to find my case interior still aesthetically pleasing, save space, and not require me to purchase new ram. However, there are SO many mixed reviews on these closed loop coolers. Some say they work perfect. Some say they are quiet. Some say they are loud and unreliable.
My priorities are sound and looks. Sounds to me like both perform equally well (depending on who you ask) so I'm turning to here for a push in some direction.
Thanks!
Thanks!
