- Dec 27, 2008
Need your input on this weird bios thing. I just replaced my PI X3 8750 BE with a Athlon II X4 630. The motherboard is an ASRock A780FullHD with the latest bios (p1.60) installed that does cover the new CPU according to the cpu compatibility table on ASRock's web site.
The problem is the bios says the max CPU voltage is 1.375 whereas AMD says the X4 630 voltage range is 0.9 to 1.425. This chip has a lot of overclocking head room but the bios ceiling is limiting me right now.
I know the board is capable of putting out more juice than 1.375 as I was running the X3 8750 at 1.435 and the bios said the max was 1.5.
What's going on here? Am I correct in assuming the bios version I'm using has a problem? What else could it be?
