OMi7000 said:Im new to OC'ng.. Simple question. If I'm flashing my vcard do I need to bring down my vAGP to 1.4.. I have set to 1.5v default
g0dM@n said:Well, if you saw an improvement with a reformat, then it is also highly likely that you could have fixed the problem with a driver clean.
In any case, how is the case airflow? Are your ambient temps extremely high all the time? Have you checked your case temp?
g0dM@n said:Well, does taking the side panel off help get rid of the thermal-throttling kicking in? What temp does it kick in at anyways?
Yes, it's an agp version, but in RivaTuner i found those values (in the Graphics subsystem diagnostic report).g0dM@n said:I would double-check... You're on an Athlon XP, so I'm sure you have the AGP version... so I guess it's possible to unlock... but I'm not sure.
You could always try doing it with Rivatuner to see if it's even possible to TRY.
