My vote is for the Gigabyte board. It's 790FX and even 790X predecessors were excellent OC'ers.
For a great cooler the TRUE Black Rev.C and some nice fans just can't be beat ...
http://www.sidewindercomputers.com/thulbledrec.html
Fans from quiet through "you'd better use a fan controller or wear earplugs"
http://www.sidewindercomputers.com/scsf63cfms12.html
http://www.sidewindercomputers.com/pa12mesp.html
http://www.sidewindercomputers.com/pa12hisp.html
http://www.sidewindercomputers.com/de12trblhisp.html
For an exceptional value and decent performance Yate Loon's are also well thought of around here:
http://www.sidewindercomputers.com/yateloonfans.html
Here's a link to muddocktor's TRUE and Megahalems testing thread:
http://www.overclockers.com/forums/showthread.php?t=629296
I do like my music, and becuase it looks like my crossfire 4870's will block off all the other PCI slots I won't be able to use my sound blaster card It's the small extras on a piece of hardware that make is specialMore than one SATA connector. If you're going to slam something you should do your homework better.
+1 internal SATA III (6 total), +2 internal SATA II, +1 eSATA (2 total), +6 USB (I think - 12 total), a better audio chip, and a few other odds and ends. Not that any of that matters much to us OC'ers but if the power system is designed to handle all that and you don't use it you'll never have any power issues.
There's nothing I like better than over-kill when it comes to power and cooling.
PS
Oh yeah, I forgot to mention the PCB cooling - and yes, it really works. I've had it as part of my ASUS boards for years and Gigabyte started doing it last year (? maybe 2008). There is a definite difference in temps if you set the board down flat on a table, I found that out the hard way ...
