- May 11, 2016
hi all, any advice for a 1st time CPU OCer.. ive managed to oc via bios & have it running stable (prime95(max heat test) hits 38c , yet cpuz stress test hits 47c, or so says hwmonitor) But i say stable when really it should be stable-ish...every few reboots/shutdown-restarts, i get the `bad checksum error`any ideas why? i can re-enter the exact same settings again & it reboots perfectly...
if i change cpu volt back down, OC doesnt work, i can adjust everything else there (Chipset,HT) in the amd OC config, is`P-States` which is off, as when on,again OC doesnt work, havent adjusted DRAM/mem timings, as when i do, the OC doesnt work... tbh im not fussed about pushing it harder, just annoying having to reconfigure bios every other time i reboot..although so far under settings in pic, ive restarted a few times & seems bios is playing ball..maybe ..so fingers crossed &/or if ive gone wrong/destroying something important..any suggestions/help would be awesomes
Heres what ive got so far:
on a Biostar N68SA mobo.
