- May 22, 2011
- USA
Here's my older setup I had just over a year ago. I have upgraded since and removed them as I didn't feel the need for them except for one setup as a drain at the bottom of my 900D. QDC's are great for a mobile or test bench system to say the least or for those that don't want to take apart their whole sysetm.
For your case OP I would place them somewhere by themselves and not on top of any chipset or electronics. Just make sure their O-rings are up to par. Once disconnected they can have a small drop or two. Than once connected they can create a few small bubbles but that shouldn't be an issue.
Here's an example of exactly what I believe you're trying to do, to be able to disconnect from each join if you were to replace/upgrade a component without draining the whole loop or redoing it for that matter.
Times have changed. Components have changed as already stated. Lots of great water cooling parts with more pumping power and better heat dissipation. Skinneelabs and Martinsliquidlab would be a great place to start.
Hope to see some pics of your finished product.
