- Nov 12, 2002
- Rootstown, OH
Paxmax said:I still have to insist;
Most of the blowers air will escape the easiest path out of the heatsink. (see pic at page 1 of topic, drawn as thick lines representing more air)
It's just like water, just like electricity, where the resistance is the smallest, thats where you'll find the highest flow.
For freakin' sake, take two straws of different diameters or lenght, blow into them, now tell me, where does it flow the most???
So, if you stick a blower(radial fan) ontop of a swiftech porcupine heatsink, you'll get most of the air escaping really close to the sides, just as "normal" axial fan would push the air.
The air doesn't want to force itself down to the bottom of the heatsink and then veer off 90 degrees and take an even longer route out of the heatsink.
Ofcoz, some miniscule amount of air will reach down there "in the venerable dead spot", but most of it will be trapped in vortices(as in vortex, I hope). My "?" in the picture posted above by me is where those vortices rule. We all think/know that vortices are good for heat exchange, but these ones are trapped, and not much air is rushing by to the rescue.
In my picture you can see thick lines representing where more air pass by... the thinner lines, the less air I predict will pass by...
Yes, the cooling of the dead spot IS BETTER with a blower, but so far as for practical solutions go, it has been a too high trade-off in CFM to make the idea work in practise.
Oh yes, radial fans has a potential to create better pressure, but that needs either high rpms(we know how that sounds) or bigger diameter paddle wheels(we all know already the devices are clumsy "as is").
Another factor speaking FOR AXIAL fans is the air coming of the blades is turbulent, and that turbulent air hits the fins/pins and then escapes the easy way to the sides.
The air from the radial fan is much less turbulent, of coz it might GET turbulent passing the fins/pins... but from the get-go the axial air is more turbulent.
Those appear as some mighty large assumptions, but knowing your posting I expect you have some reasons for thinking such besides just general theory.
Good quality blowers have been shown to perform quite well also... I don't know what you mean by "as for practical solutions go, it has been a too high trade-off in CFM to make the idea work in practise". Look at Hoot's article I linked earlier - and my current case and PSU has no fans but my centrifugal blower - there is no axial fan that can do that at any reasonable noise level.
Relative to Axial fans, even moderately sized wheels in centrifugal blowers produce much better pressure. They are clumsier than axial fans though, I'm right with you there - they definetly require some creativity to implement a real good blower elegantly.
Turbulence created by the fan has very little do with thermal transfer by air in these applications - it is different than water in the respect that we are dealing with volumes in the range of 70 cubic feet per minute easily with blowers. Turbulence helps with heat transfer with water in our applications because it gets more molecules involved given the same reasonable flow rates that are typical - but dealing with such large volumes of air, turbulence is much less necessary. Air flows freely enough that turbulence is neglible relative to total flow volume.
I'd like to know where your coming from with your view, and if you have links or anything you could refer me to so that I can understand it a little better.
