- Mar 29, 2008
Hi, for some reason i seem to be having a boot problem and i can't seem to find a reason or permanent fix for it.
I have an abit ip35 dark raider, and it's always started up with fans on highest speed, shut down then started up again with fans on high speed, fans then slow down and it and worked, i think this is usual with p35 boards and just requires a flash to fix it, i've never bothered fixing it though as i don't really see it as a problem.
Now though, it starts up with fans on high speed, shuts down and starts up again with fans on high speed and stays like this. I can't get it to start up at all unless i reset the CMOS and remove the CMOS battery for about 15 mins. I used to have a q6600 oc'ed to 3.2ghz but now i can't keep my oc because i have to continually do the steps above to get it to boot, whenever i try to save any BIOS settings and restart the computer it will have the same boot problem as before. I have no case speaker either. Latest change to build was a new hdd on the 8th of march, the problem started occurring on 3rd august and i was on hols from 4th-23rd. On the night of the 3rd my grandfather touched the computer and could have somehow broken it
Specs:
Abit ip35 dark raider
q6600
TRUE
8gb ddr2-800 g.skill ram
seagate 7200.11 320gb (primary drive)
samsung f1 1tb (bought later for more storage)
nvidia 9800gx2
cm stacker 831
samsung sm245b
Hi, haven't been here in a while but i think this is the place where i'm most likely to find good help. I posted the previous quote a few weeks ago on another forum and one member suggested that it was a problem with the CMOS battery as i always turn off the main power supply when i turn off the computer and so there's no auxiliary power from the psu.
A few days after i'd posted the thread, i managed to get the computer to boot by setting the CMOS jumper to reset, removing the battery, turning mains off, waiting for about 10 minutes and then plugging in the CMOS battery, powering up and setting the jumper to normal, i also stopped turning the mains off when i shutdown the computer and the problem seem to have disappeared (the bios had totally reset, lost my oc, had to reset time etc), apart from a message i got at bootup "cpu is unworkable or has been changed, press f1 ro continue" or sometimes "cmos checksum error"
Today, while still using my computer with the temporary fix, i started getting artefacts and the computer powered down and restarted, i also got a blue screen but the computer restarted (forgot to set it to leave the bsod on screen) and hung on the post screen, i tried going through the same method as prev stated to reset the bios and i managed to boot and stay on for about 10 mins after getting artefacts again and the computer restarting and hanging on the post screen
can anyone help?
