- Oct 15, 2012
Hello again OCers,
I left my custom-built PC on the first night after installing windows 7 to CHKDSK /r for bad sectors because I had some HDD related BSODs earlier (see below) and stayed near until the results screen. (which took 4 hours to get there for my 3TB HDD)
The results were all good, no bad sectors.
But then it stayed in the 'Please wait while your computer restarts' state for 5+ minutes and I just went to bed.
The following morning I found that my computer had not restarted but rather had shut itself down, since all the power was off.
I hit the power button, got through mobo screen but then I got the BSOD "STOP: 0x0000001E"
The next time I started it (2 min later) it asked me whether I wanted to start windows normally after showing mobo screen, I chose yes to see whether the BSOD would repeat (it didn't)
Then it seemed like the DVI connection to my monitor (which is plugged into my mobo, not GPU) lost power for 2 seconds before regaining it and turning full black for 10 seconds.
It then showed the "starting windows" screen but after that for a while (10+ minutes) all I saw was the windows background with the flag, nothing else on screen, not even the cursor.
I decided it wasn't gonna start and held down the power button to shut it down.
Since I have an ASRock mobo I might as well mention that the Dr Debug display was off.
Haven't tried starting it since, because I thought it'd be better to ask you guys what's up first
EDIT: I did start it just now and I get exactly the same thing: mobo screen, monitor power loss, black screen, windows is starting screen, windows background.
I also got 0x0000007A and 0x000000F4 BSODs earlier which I both 'fixed' (as in none of those kinds of BSODs since then) by replugging the cables on my HDD twice, once for every BSOD.
And before I replugged the cables the first time for the 7A BSOD, my pc was hanging every couple of minutes for some seconds semi-randomly (this has not occurred since the replug)
Link to my full setup: http://pcpartpicker.com/p/IJe4
I should mention that the Card Reader, BluRay Writer and iiyama Monitor are not currently connected and I'm using some old DVI monitor (monitor and BluRay writer have yet to arrive)
EDIT: Forgot to mention, none of my parts are OC'd yet.
EDIT 2: Also, I had just installed all the 'important' and 3 'optional' windows updates before this happened (since I did a clean/custom windows 7 install)
I hope you can help me,
-XDMickeYXD
-XDMickeYXD
