- Jan 10, 2012
time to throw boinc at it.
It is rather difficult to diagnose issues with other people Pc's when one cannot put their hands physically on that Pc and see what is what. Only way of trying to figure out what is going on is by asking questions or making suggestions. You installing several versions since the Re-install of windows only makes me think more that it could be an issue with the Oc. Apparently, you do not feel the same, the only other solution to see what is causing the issue is trying what Scotty posted below. Good luck.Did I accidentally end up on the forum for conversation?
Mandrake - That's a good thought. However, I've had several versions since the win7 reinstall, and the behavior hasn't changed.
Mr. Scott - (big Star Trek fan here) That depends on your definition of stable. Only one application giving me headaches. I'd call that stable captain, and a wee bit more.
AgreedEasy enough to find out. Run BOINC at stock. If it doesn't BSOD.......your OC was unstable. No point in arguing stability.
Scotty - I have no doubt that my PC, like the hundred plus at work, will run BOINC without blue-screening if I run at stock. LOOK AT THE SUBJECT LINE OF MY POST.
I am grateful for the efforts so far, but if there is anyone else who can grasp what I'm asking, and has expertise in this area, I would really appreciate your input.
I offered Zero insight? Really? I'm sorry that while trying to help you offered Zero insight. I am not here getting paid to try and help you, I'm doing it because I enjoy helping, sometimes... I posted what I did because I felt that it could be helpful, sorry you feel differently. Considering you made Zero attempt to even try what was asked there is not much I can do. Again I'm sitting hundreds of miles away on my own Pc and cannot get my hands on yours. Here is your simple Oc, add Cpu voltage until it no longer Bluescreens running seti or your heat load is above 85c.I rarely post to sites seeking answers, and this experience is reminding me why.
Mandrake - You start by making an observation that everyone already knows, and offers zero insight. Then you misconstrue what I have tried with great care to express clearly, and concisely. I clearly indicated in the very beginning that I was seeking advice on how to tweak the OC so as to stop the BSOD's that occur while runing BOINC
So this has been a great waste of time.
