- Dec 27, 2008
It cost me a lot of "bucks." Going naked that is.
Tried it a couple of days ago and killed both my cherry 4790k and the mobo. Bent pins in the socket and could not get them straightened out. Not sure if the bent pins fried the cpu or if somenthing else happened to the CPU (no physical damage to the eye). But I tried the CPU in another compatible board and it exhibited the same restart looping over and over cycle with no boot, no post. Four quick bios beeps. Tried adjusting the tension on the mount up and down but no love.
And this attempt was made with the certified EK Supremacy Evo precision mount "naked" kit, their water block. Had all the right stuff.
Now I'm not feeling sorry for myself. I knew the risks. I've come to the conclusion that the socket just needs the lid to distribute pressure correctly. And with the retention clip removed it's so easy for the CPU to slide in the socket as you'r mounting the block.
So now I'm down to an i3 Skylake which, truth be told, is quite adequate for the kind of computing I do. It runs real cool with a 3x120 fan water system, even with the fans turned off running IBT.
Any CPUs I own will remain covered from here on out. Oh well, education has always been costly.
Oh, yea. I need to update my Sig soon.
