Here is the matching stick.Looking for some inexpensive memory for the mobo listed, I currently have an 8GB stick of the Kingston HyperX FURY Black, (HX421C14FB/8) which I believe is single channel?
At any rate I do a lot of gaming but zero OC.
https://www.amazon.com/HyperX-Kingston-Technology-Internal-HX424C15FB2/dp/B01D8U2BKA
Or get a new set like trents also suggested.
My point of the post was “budget”, I’m moving that 8GB stick elsewhere and need a cheaper option, I originally paid 35 bucks for that memory 2 years ago, I really don’t want to pay 75 for another stick, can I get 16GB of RAM for cheaper? Or is that the going rate these days?Oops! Thought is was the exact stick (shakes fist at google and myself for not double checking)... see if you can find it. If not, trents has you covered... same speed/voltage/timings/capcity stick, or get 2x8GB set.
That's for AMD though correct?This is the best price I have seen for a dual channel 16gb kit: https://www.newegg.com/Product/Product.aspx?Item=N82E16820232509
Name brand, too. Memory is as cheap right now as I have seen it in a long time. Prices a year ago were sky high and have come down a lot.
I don't imagine it to matter... AMD ram just means it was tested on AMD platform to work. Either or will be fine in all likelyhood.
Designed for AMD Platforms
Returning from the ashes, the new AMD architecture features a completely different set of memory enhancements, requiring a new approach. The Flare X memory series is designed with a distinct characteristic to optimize compatibility with the latest AMD platform. http://www.gskill.com/en/product/f4-2133c15d-16gfx
What about this set of 2x8GB? Dual channel I assume? I'm guessing I will benefit from the jump to 16GB regardless of the timings correct? I believe these are "slower" than my current Kingston HyperX?
Or even this?
