I'm in the process of building a budget Athlon 64 3200+ system. It is a work in progress. I don't want to jump on it until many people review it and I know it is the best bang-for-the-buck overclock Athlon 64 system I can build. I need help with it: I am very unsure about the motherboard I should get. Also, I'm not quite sure about the RAM I should pick and I need help picking a PSU as well. I would apprecieate any help or pointers.
Here are the parts I'm pretty sure about getting (if anyone has a recommendation, please share it):
Already bought this a while back, can't change it
XBlade w/Crappy Generic 450 Watt PSU [18A on 12V] and LCD Controller
$75.00
Very quiet and high performance cooling
Thermaltake SILENT BOOST For AMD Opteron and Athlon 64 (All Copper) -RETAIL
$27.95
For rear case exaust (I have 3 other fans already for intake and stuff)
Thermaltake A2018 DC Fan Seires - Smart Case Blue LED 120mm Cooling Fan Retail
$17.95
Two of these babies for speed and diskspace. 400GB of space coupled with the performance boost of RAID0 (SATA to top it off) for $260 makes me moist.
2x Seagate 200GB 7200RPM Barracuda 7200.7 SATA Hard Drive, Model ST3200822AS, OEM Drive Only
$132.00 * 2 = $264.00
What else other than this awesome card? Gonna (try to) overclock it to Ultra speeds
BFG Technologies GeForce 6800 GT OC 256MB GDDR3 AGP Graphics Card
$399.99
Total for Definite Parts: $784.99
Now, for the stuff I'm unsure about... I need a PSU, a CPU, RAM, and a MotherBoard.
PSU: I currently have a generic 450 watt. I realize the PSU is an important component of the system. I know one guy whos PSU died and took a good chunk of his system with it, therefore I don't want to skimp on the PSU. Here are some questions I have:
How strong should my PSU be? An Athlon 64 3200+ with a GF6800GT both being overclocked seems very DEMANDING.
What company should I get it from? Antec? Enermax?
Should I get a PSU with two seperate 12V rails like this one (click on the picture of the sticker on the powersupply to see the PSU's actual stats)?
CPU: I want an AMD Athlon 64 3200+ Clawhamer, 2000MHZ core, 1MB L2 Cache, Revision CG (the C0 revision runs hot and doesn't overclock worth crap).
I plan to push the chip very far. If I can get my hands on a revision CG chip I will probably be able to get about 2400MHz-2500MHz considering that people with STOCK cooling have gotten those speeds stably. RAM and motherboard selection is of great concern to me as they have a lot to do with being able to get a good overclock.
RAM: I definately want 1GB. I was originally gonna go for Corsair TWINX1024-3200C2 1GB DDR400 XMS3200 and overclock it but I think it will be smarter to go with two Kingmax TSOP 184-Pin 512MB DDR PC-4000 and "underclock" it (to get 2400MHz, the CPU will be running at 240MHz "FSB" or DDR480: below the spec for the DDR500 Kingmax RAM). The ram has a CAS of 3 however I might be able to tighten it to 2.5 because I will be running it under spec.
What do you all think about going for faster RAM and clocking it down? Is it wiser to get higher speed RAM from a less established company and run it below its limit at or better than spec timings or is it wiser to get lower speed RAM from the "overclocking king" Corsair and push the RAM till it bleeds probably sacrificing timings? (The price of the Kingmax is lower than the corsair. Also, keep in mind that this isn't Corsair's ultimate preformance ram, that sutff is lik $320 for 1GB PC3200: way out of budget).
Motherboard: No Clue... I want the nVidia nForce 250Gb chipset though.
I read that the Epox Athlon 64 board is awesome for overclocking but it lacks firewire ports
I read that the Gigabyte board has some issues stability at rated specs and RAM being forced to run at 166MHz. I read also that it does not overclock as well as the Epox board, that it also lacks firewire ports, and it is based on the nForce 250 non-Gb version. It doesn't seem to be a good pick at all...
I read that the MSI Neo KN8 has SEVERE issues and has been an overall headache for everyone...
Asus boards are plauged with issues... 3 of my friends all got asus boards, one refused to work with an all-in-wonder card, one was extreemly unstable and shortly thereafter DIED, and the last was DOA and so was the second replacement board he got... so I don't trust Asus. Their customer support is sad too.
So I don't know what motherboard I should get. So far, the Epox looks the most promising... Haven't read about any issues with that board YET.
Thanks guys.
Side Note: My dilema. There is no way of knowing which revision of the Athlon 64 you will get. So if I get a C0 revision I'm TOTALLY screwed as far as overclocking goes. Anyone know of a store that is selling CG revision AMD Athlon 64 3200+? the CG revision model numbers end with AR, AX, or AW. The C0 revision ends with AP (SO THATS BADBADBADB). The crazy thing is some people order from places saying they are selling the old revision but they get the new one (which is very good) but I would like to eliminate this chance... Thanks
$75.00
$27.95
$17.95
$399.99
Thanks guys.
