Budget & Performance AMD Athlon 64 3200+ system. Need tips.
Hmm. I don't have any tools to do mods with :(
a blowhole up top would be nice...
the case doesn't have the best circulation in the world. Trying to combat that with the two 120mm, and two 90mm fans. A blowhole would make things so much better tho.
hmm, ill look into that. Is there a particular one you'dd recommend? Also, should I practice on sheet metal first?
well i have a Blu mole hole saw, and it is pretty good,
and the dremal ,well i would stick with only Dremal, or Black and Decker, those two are the best
Thanks, Ill look into that and probably try to cut a blowhole (or two) if the tools aren't too expensive.
