Hi! I'm starting this build to replace my current ancient PC and to be able to play and develop for VR in the near future. I don't have a big budget right now, so my first step is to purchase everything except GPU and the headset itself.
I need to MATCH the minimum requirements for a VR ready rig. I don't want better, nor do I have money for it. And I want to save money, and yet get a decent reliable PC. So I found a local store with the best prices and pretty good catalog and chose some parts. First, here are a few important questions I have:
1) Why HTC are suggesting FX-8350 as an AMD equivalent of i5-4590? Why not FX-4350 which outperforms i5-4590 in benchmarks like futuremark, and especially since 8 cores shouldn't have any noticeable advantage over 4 cores on FX-4350. One is twice as cheap as the other $150 vs $80, and i5 is $200. So do you think FX-4350 would match i5-4590?
2) If FX-4350 is slower than i5-4590 then what would it take to match it's performance? (Not much I assume..) And since I've never done overclocking, can you tell me what kind of heat sink would I need to overclock it, considering there can also be good air circulation in the case? How much extra heat will CPU produce?
If you'll help me to figure out those things, I'll be able to get into build details, I need some advice there as well.
Thank you!
Thank you!
