- Jun 26, 2014
Alright, so I had been discussing my future build with a few people (namely Mandrake) on another thread. We agreed it'd be a good idea to post my items that I was interested in purchasing before actually buying anything to help avoid issues like the Kingston fiasco and buying something that wouldn't be upgradable later on (The Asrock Killer Fatal1ty).
In any case, I'm going to list what items I have as of right now, plus the list I have saved on Newegg for later purchasing. Here we go!
Three Noctua NF-S12A PWM 120mm Case Fan
Thinking about getting two F12's to probably replace the SP120's on the H105 I have on the list as well.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608038
CORSAIR Hydro Series H105 Extreme Performance 240mm Liquid CPU Cooler
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16835181060
(x2)
G.SKILL Ripjaws X Series 8GB 240-Pin DDR3 SDRAM DDR3 1600
I think I'm gonna get just one to start off with the offset the high cost, then just purchase another one later on down the line.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231488
AMD FX-8350 Black Edition Vishera 8-Core 4.0GHz
Of course gonna get me an 8350. :3 I've heard with careful overclocking and a good cooling solution, you can pump these bad boys up to 5gigs.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
ASUS SABERTOOTH 990FX R2.0
I actually found an open box version on Newegg for about 35-40 bucks cheaper than the retail version. I'd like to get the open box one, but if you guys think I should just save the 50 and get the retail, then I will.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131877R
DIYPC Adventurer-9601R Black/Red Steel Gaming
This is a simple Mid-Full sized tower with 5 fan slots all come preinstalled but I think I'm going to end up replacing them with Noc fans anyways. It also comes with a dual 120 slot uptop for the radiator I'm getting.
Those are the things I'm planning to get, here's what I already have:
Kingston SSDNow V300 Series
Unfortunately, buying this SSD was a mistake. I've already ranted about it in a seperate thread, but this is what I have as a boot drive.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16820721107
Seagate Barracuda ST1000DM003 1TB 7200 RPM
For storage, I have a Barracuda TB drive. Eventually, I want to switch to either a Raptor, or a WD Black, but this'll do for now. It serves my purposes.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
RAIDMAX HYBRID 2 RX-630SS 630W ATX12V V2.2/ EPS12V
This here be mah PSU. It's done me well so far and has powered everything in my ancient build just fine.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817152035
ASUS DirectCU II R9270X-DC2T-2GD5 Radeon R9 270X 2GB
My graphics card which is pretty decent. I haven't been able to push it to it's fullest extent yet due to multiple factors, a few being the CPU bottleneck I have at the moment (Q6600), and cooling since the case only has two intakes and one exhaust.
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121802R
And that's it. My current build isn't all that important since it doesn't matter. I'm not keeping anything besides what I listed above. So CRITICISM! Let me have it!
And thanks in advance.
(x2)
