I love my Cosmos II, although a word of warning: the top cover is very anti-airflow. My Radeon R9 295X2's rad sits up there (in push/pull)
When I remove the top cover, GPU temps fall by 5C or more. If I do not remove the top cover, it gets QUITE hot to the touch. (I cleaned off any/all dust to make sure since I had the case since ~2012, same effect)
Thanks! I found out I had the Aquaero set in voltage adjust mode for the first test. With PWM, it can't technically do full 100% power. Something about how the signal works. So I could use the fans in voltage mode which gives me the option to do true full power, but then the fans don't adjust nearly as much. I have enough cooling capacity in there, I'd rather the option to go super quiet. Technically, the Aquaero could handle all the fan clusters except the cluster of 6, but if I was power injecting for one, why not all? There really only needs to be two wires from the Aquaero for each header. They're dead points on the one side of the PCB. I'm doing all 4 wires though for aesthetics.
