- Sep 27, 2003
I've got an AM2 6000+ 3.0ghz windsor. I'm most likely gonna use that and want an upgrade path for the future. This build is not for me but it's on a budget.
Here are the boards I was looking at:
Seriously considering the ones in yellow. I want to go for the Zotac b/c it's only $50 AR!!! If that's a bad choice then I was strongly thinking about the AsRock, but again the Zotac is super cheap... just want to know if it's worth a shot.
The one in blue is also up in the air... the rest are mostly out of budget but just was looking at 'em.
What do ya think? I've a feeling most of you will say the Zotac isn't worth the headache and to settle for the ASRock?
- ZOTAC GF8200-A-E AM2+/AM2 NVIDIA GeForce 8200 Micro ATX AMD Motherboard - Link
- ASRock A780GMH/128M AM2+/AM3 AMD 780G HDMI Micro ATX AMD Motherboard - Link
- BIOSTAR TA760G M2+ AM2+/AM2 AMD 760G Micro ATX AMD Motherboard - Link
- ASUS M3N78-VM AM2+/AM2 NVIDIA GeForce 8200 HDMI Micro ATX AMD Motherboard - Link
- GIGABYTE GA-MA78GM-US2H AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard - Link
