- Jan 24, 2002
Hi,
I have been out of it for a while. Building a new system now based on Supermicro X11DPG-QT with 2 Xeon Scalable Silver 4114.
Not a gamer - sorry. Not an overclocker - I am really, really sorry.
Checking out the current memory prices, my jaw dropped. The cheapest on Newegg is:
Kingston ValueRAM 8GB (1 x 8GB) DDR4 2400 RAM (Server Memory) ECC Reg DIMM (288-Pin) KVR24R17S8/8:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820242286
1. MEMORY: Is the above memory any good or should I avoid it?
2. CASE: Could you recommend a 11 PCI slot case that would take the above motherboard. (Supermicro cases are too expensive) It should be able to take at least 8 X 3.5"HDDs.
Keep in mind thatthis motherboard is extended to the right - please see the picture on Supermicro's website - link above. Normal motherboards end with the last rectangular silver block - the Ethernet/USB ports at the top-right. The serial port at the very top-right and the memory slots below it and then the power connectors below that is the area of the motherboard that is extra. (UPDATE 1 BELOW) I remember finding a big case like that years ago but can't find the link now.
Will post additional questions as they come.
Thank you for your help!
UPDATE 1:
I took a hi-rez picture of the motherboard from the pdf manual and superimposed it in Photoshop on top of a picture of a motherboard tray from a HPTX case. Most of the holes in the mobo matched with holes in the tray and the ports of the mobo matched with the opening for them. So the information I posted above is incorrect (strike through)
3. The motherboard requires 4 power connections. The standard 24-Pin then two 8-Pin and then a 4-Pin connector. My power supply does not have the 4-Pin one. Is this good enough fix?
Keep in mind that
UPDATE 1:
