That did the trick.
Huh ? Are you saying that its now working at the sanyo denki fan ?
That did the trick.
For your enjoyment. I don't have a proper work bench, so don't laugh.
It almost spun off on me.
Sanyo Denki on Steroids with Fan controller.
Found this. Noise suppression for PWM circuit. Helps eliminate acoustic noise.
What do you think?
http://www.jimfranklin.info/microchipdatasheets/00771b.pdf
Ok Project PWM for SANYO DENKI - 9SG1212P1G01
This may apply to Delta as well depending on project results.
Goal, ~1000 RPM (tolerable noise level) up to 6000 RPM (Full Load) Pulse Width Modulation from Motherboard with Voltage draw from Power Supply.
List of parts needed.
Will a lower PWM of 1000 RPMs result in no performance on these fans?
All input is welcome. These questions are primarily directed at bing/mudd
I built one for my ITX switch PC but unfortunately I no longer have it. I to ran into the same problem, its not really something that is mass produced and its not that simple of a concept. I was able to get a crude one working from some mosfets and motherboard rpm sensing.
Motorized pots and a switch make for a really clean install, assuming you can go by the fan's noise instead of "knob angle". I had 4 controlling a quad-LM317 fan bus I made, although it still kinda sucked being 11.5v to 6v. This was before PWM fans. FYI make a limit stop to keep the motorized pot from dropping below the fan's cutout pwm/rpm (if you want).
The other (cheap) method could be a slide pot. You can get one with a thin "blade" handle that could mount between a gap in your case somewhere. Otherwise it would go through an elongated hole and look like a switch with a very long throw.
