- Nov 16, 2012
I just built my first custom PC. Here’s my Build:
CPU: AMD Trinity A8-5600K 3.6GHz APU (CPU + GPU)
RAM: 8GB G.SKILL 240-Pin DDR3 SDRAM 1600 Desktop Memory
MB: MSI FM2-A75MA-E35 Micro ATX AMD Motherboard
PSU: APEVIA ATX-CW500WP4 500W Power Supply
HDD: Seagate Barracuda Green 1.5TB 3.5" SATA 6.0Gb/s Internal Hard Drive
DVD Burner: LG DVD Burner Black SATA Model GH24NS90
Case: GIGABYTE GZ-P5 Plus GZ-P5HB5C Black Computer Case
So I did an external build first to test all the components. I placed the cpu into the FM2 socket on the motherboard, then I put the stock cpu fan on top, but I had some trouble attaching it to the latches on the motherboard, so I took it off the motherboard to try it the other way. The cpu came off with it because of the thermal paste, so I had to pry the cpu off the bottom of the fan and re-seat it on the motherboard. I’m pretty sure I got it in right (it only goes in one way), and I’m positive there weren’t any bent pins. So put the cpu fan on the correct way an latched it on. Then I installed the ram, plugged the cpu fan into the MoBo, plugged the PSU into the MoBo and the CPU power socket on the MoBo, plugged the PSU into the wall and shorted the PWR SW pins to test the build. The fans in the PSU and the cpu fan started running, so I assumed it was a successful build. I carefully installed the MoBo with the cpu, cpu fan, and ram into the case then I put the PSU, the HDD and the DVD Burner in and plugged everything in. I hooked the PC up to a Brand-new ASUS HD monitor via the VGA cable that came with the Monitor, and turned it on. All the fans and lights on the case turned on, and the CPU and PSU fans started running, and I was feeling pretty proud of myself. The monitor came on, gave me a quick ASUS splash screen, and then said ‘VGA NO SIGNAL’. . Everything in the PC kept running until I turned it off. I tried turning it on and off again with the same results. I poked around inside the case, but I couldn’t find anything wrong. The only thing I can think of is that maybe the power supply is bad or the cpu is toast.
PLEASE HELP!!!
PLEASE HELP!!!
