As I read through the posts, it seems that recieving cpus with certain stepping/revision codes is like hitting the lotto to some.
When buying a cpu, can you request a certain stepping/revision code? If so, how and where. Or is it the luck of the draw? Looking at buying 1700+ or 2100+ T-bred and wanted to be sure before I purchase.
Thanks in advance.
Thanks in advance.
