Speciale
Disabled
- May 29, 2005
- woodstock illinois
I'm trying to slowly teach myself some basic C++ programming. A few years ago i bought C++ for dummies...it was the easiest of the lot to read and so i figured it was a good place to start (all the other books kind of made it seem like you needed some sort of backround).
At any rate it came with a compiler and the programs it has you program worked fine. I lost that disk and now use i'm using C++ visual express, and i've tried another free one from the web.
The very first program:
When i try and compile it i get this error:
originally it is suppose to be
And i get the same error. It's my understanding that the iostream.h and stdio.h define cin and cout...am i right?
I've tried to look them up online and they seem very common, it seems that this should work. Someone want to explain to me where the error is??
Code:
// Program to convert temperature from Celsius degree
// units into Fahrenheit degree units:
// Fahrenheit = Celsius * (212 - 32)/100 + 32
#include <stdio>
#include <iostream>
int main(int nNumberofArgs, char* pszArgs[])
// enter the temperature in Celsius
int celsius;
cout << "Enter the temperature in Celsius:";
cin >> celsius;
// calculate conversion factor for Celsius
// To Fahrenheit
int factor;
factor = 212 - 32;
//use conversion factor to convert Celsius
// into Fahrenheit values
int fahreneit;
fahrenheit = factor * celsius/100 + 32;
// output the results
cout << "Fahrenheit value is:";
cout << fahrenheit;
return 0;
------ Build started: Project: C++, Configuration: Debug Win32 ------
Compiling...
temp conversion.cpp
.\temp conversion.cpp(7) : fatal error C1083: Cannot open include file: 'stdio': No such file or directory
Build log was saved at "file://c:\Documents and Settings\Tim\My Documents\Visual Studio 2005\Projects\C++\C++\Debug\BuildLog.htm"
C++ - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Code:
#include <iostream.h>
#include <stdio.h>
