I am planning on building a server rig in my desk. I currently have my gaming PC setup on one side of my desk with my server pc going into the space on the other side of my desk.
The Hardware:
MSX350 water pump ( I also have a DDC from Alphacool I was going to add to the loop to pump water to the server PC)
EK Crosshero VI CPU&VRM waterblock
400mm Radiator ( its dual 200mm from Phobya Extreme)
I plan on adding a Vega GPU and waterblock when release in a few months and just a CPU waterblock on the server side of the desk. Does anyone have experience with a setup similar? I'm would like to know if I can use just the one radiator? My TDP calculations for it was around 1400 watts it can displace. I know the Ryzen 1800x and a Vega GPU wont even put a dent on it. I more concern about using the Alphacool pump to supply the server CPU cooling. Would the pumps work or would they have to run at the same speed or could I just use one pump for both systems? The radiator is in center installed as exhaust. desk is pretty sealed. Four 180mm intake fans, 2 per computer side and two 200mm exhaust in rear. the center chamber has no air flow.
The Hardware:
