A andyfoz Registered Joined Feb 20, 2006 Mar 13, 2006 #1 Can i buy a mac monitor and use it on my PC? its an apple 23 inch hd screen taken from a mac will it work on my x800xl or will it need a converter or should i not bother ? thanks
JCLW Member Joined Apr 1, 2002 Mar 13, 2006 #2 You can. There are two versions of the 23". The old one has an ADC connector, so you'll need an ADC <-> DVI cable (or adapter). The newer one is DVI.
OP A andyfoz Registered Joined Feb 20, 2006 Mar 13, 2006 Thread Starter #3 http://cgi.ebay.co.uk/New-Mac-G4-G5...ryZ25449QQssPageNameZWD2VQQrdZ1QQcmdZViewItem would this be the part or is it the wrong way round?
moz_21 Member Joined Jul 7, 2002 Location MN Mar 13, 2006 #4 You need it the other way around, yep.
JCLW Member Joined Apr 1, 2002 Mar 13, 2006 #5 Like this: http://www.gefen.com/kvm/product.jsp?prod_id=1203
OP A andyfoz Registered Joined Feb 20, 2006 Mar 13, 2006 Thread Starter #6 so as its the other way round it cost 10 times more what a rip off
JCLW Member Joined Apr 1, 2002 Mar 14, 2006 #8 Yes, you probably could. That was just the first one google pulled up. You could even make one if you wanted. There is no signal conversion, its just DVI + USB on one cable. But first find out if the screen has an ADC or DVI connector.
