I have an intel 2.8 Prescott 1mb cache, 865PERL mobo, TT POLO 3 in 1 hs (lapped 2k grit), AS5 1/3 of a bb on cpu spreaded with cc. I replaced the fan on the heatsink with the 80mm vantec tornado mounted on a TT duct mod. I have a sunbeam duct mod also but it doesn’t fit in my case heh. As for case setup I have a vantec tornado on the blowhole, one vantec 80mm silence and 1 vantect tornado in front as intake, same setup at the back for sucking out the hot air. I also cleaned up my wire inside my case a lil bit. My temp b4 modding all these stuff is ambient 35, CPU idle at around 50-54, and loaded temp is about 63, the after temp is ambient 30c or so, idle 42-44c, and load temp is at 54-56c. A big improvement I know but I was wondering is there a way to improve it further without going water? I was thinking of cutting the front grills off to improve airflow but that is kind of a pain in the butt because it has little holes as grills instead of your usual.
