Boot lockups.
In my recent amateur review of the OCZ Synapse caching solution, I noted that the system locked up on boot pretty much every other day when starting from dead cold in the morning. Turns out, this results in the Dataplex software cache not just verifying its contents, it also starts the caching process all over again. This might explain why some people have such good results with the Synapse and my results were underwhelming. Most reviews reported 10-15 sec boot times. Mine (per Event Logs) were in the 45-60 sec range.
Now, I still have a window of opportunity to return the Synapse, but I'm wondering if I should hold off.
Two questions:
Is is at all possible that installing a SATA3 add-in card and running the Synapse off that will improve stability?
How much performance loss is there really with a SATA3 drive on a SATA2 port? Is it worth the cost of a SATA3 card? I'm aware that SATA3 theoretical bandwidth is 768 MB/s, whereas SATA2 is 384 MB/s. Using AS SSD, the drive tests at 200 MB/s read, 60 MB/s write. ATTO tops out at ~250 MB/s for writes, ~280 MB/s for reads using a a 2 GB test length and QD 4.
The card I'd be considering would be PCIe x1 card from Newegg. Something in the < $40 class.
Two questions:
