- Feb 18, 2002
My thoughts are the same as what you've already been told:
I've never done this but
Be sure to carefully read:
http://www.arcticsilver.com/arctic_alumina_instructions.htm
http://www.arcticsilver.com/ceramique_instructions.htm
Finally look into correct heatsink mounting.
99% alcohol is better than 95% alcohol. Let it dry after cleaning it.
Lapping is the process of sanding the bottom of the heatsink, so that it is very smooth and shiny. When you first receive your heatsink, run your fingernail across the bottom of it and you will feel lots of little ridges or bumps. The purpose of lapping is to remove these ridges.
What you want to do is take a piece of wet sandpaper and lay it on a smooth flat surface, and then set the heatsink on the sandpaper. I use a figure 8 motion to sand the bottom of the heatsink myself. I start with a 600 grit sandpaper, then move up to a 1000 grit, and finally a 1500 grit. When finished, the bottom of the heatsink should be smooth and shiny looking.
