Hi there,
I'm having trouble trying to overclock my cpu.
On my last mobo (MSI H81) I was able to raise the clock up to 3.8 on stock cooler.
Now, whenever I tweak anything concerning core ratio or voltage I'm rewarded with either one of the next 2 scenarios.
1. If i try to OC. Past 3.7 I get a system failure and boot loop and I'm required to clear the CMOS this also happens if I choose any preset.
2. If I try to OC to 3.7 or below, Im able to save and boot into Windows normally but none of the changes I set in the bios are actually applied to the CPU. (CPUZ and System confirm that )
I'm relatively new to Ocing so here is an explanation of the settings I have fiddle with.
AI Overclock tuner* > Manual
BCLK Frequency**** > 100.0
1-Core Ratio Limit** > 3.7 up to 4.5
Min.CPU Cache Ratio > 20 up to 32 (can't get higher)
Max. CPU Cache Ratio > 20 up to 32 (same)
CPU Core Voltage** >1.1.v up to 1.23.v
CPU Cache Voltage* > 1.16.v
CPU System Agent Voltage* > 085.v
CPU Analog I/O Voltage* > 1.0.v
CPU Digital I/O Voltage* > 1.05.v
Initial CPU Input Voltage > 1.68.v
Eventual CPU Input Voltage* 1.68.v
CPU Spread Spectrum > Disabled
Enhanced Intel SpeedStep Technology > Disabled
CPU C-States > Disabled
Hope someone can help me out!
Cheers!
My system specs
Motherboard > Asus Maximus vii Gene
CPU > Pentium G3258 AE
GPU > MSI GTX 750TI
RAM > Kingston Hyper X Savage 2x4gb
Cooler > Corsair H100i Extreme
OS Storage > 2x120gb Kingston Hyper X Fury on Raid0
Storage > Seagate Barracuda 7200 rpm HDD
PSU > CoolerMaster B500
Case > Fractal Design Define R4 Black Pearl
Cheers!
My system specs
GPU > MSI GTX 750TI
