Hello,
I would appreciate some expert tips regarding my attempts to overclock my Strix GTX 970 card. It seems like I can't keep my GPU stable under any significant overclock at all.
Last settings I applied were as follows:
Power: 120%
Core Clock offset: +125 (experiencing artifacts on +175, +150 is just not stable, but no artifacts).
Memory Clock offset: 0 (I've read that on cards like mine there is no decent cooling on VRAM, any comments on that, please?)
Core Voltage offset: 0 (don't want to increase it yet, although I'm considering it in general. Just not sure what values are safe and what are not).
With those values I'm still experiencing "hard" freezes after like half an hour playing some GPU-consuming games. Is it worth trying to get a stable overclock with <100 MHz Core Clock offset? I've configured my GPU fans so they keep my temp under 60-62 degrees under full load. My GPU's ASIC quality is 69.9%, if it matters somehow.
Thanks in advance!
UPD: My system specs:
CPU: i5-3570K @ 4.1 GHz (with auto voltage)
CPU Cooler: DeepCool IceEdge 300
MB: ASUS P8Z77-M
GPU: ASUS Strix GTX 970
RAM: 16 GB DDR3
PSU: AeroCool VP-650 (650 W)
Case: AeroCool Predator X1
I'm using MSI Afterburner, although I tried EVGA Precision X and ASUS GPU Tweak with same outcome.
Power: 120%
Thanks in advance!
MB: ASUS P8Z77-M
RAM: 16 GB DDR3
