I've tried 3 or 4 times now and just cannot seem to get the VID trick to show higher than stock voltage on my 633 Cel (@988)....cB0 step. I'm trying for a solid >1.0G and it gets flakey @ 997 with 1.825V (posts/loads, but locks in PCMark). I don't think temps are a problem...~27°C stressed @ 1.825V and 988 clock.
As per the write-up on the main page, I set the Vcore voltage as low as possible in the BIOS, pulled the CPU, inserted a strand of wire across the two holes (VID3/VSS), and Vcore remains minumum. Inadvertently, it posts and loads Windows with stock clock @ 1.25V!? Talk about a cool CPU
I thought maybe the strand wasn't making good enough contact, so I pulled the CPU and added a second strand across the holes. The CPU goes in pretty tight, so I am kind of reluctant to try a third (or a single larger strand) at this point.
I figure that even if the mobo itself limits it to the 1.825V, it would still show up as that with the wire trick performed no matter what the BIOS settings are. Is that correct? And before I beat my brains out trying to get it to work, what is the possibility that I AM limited to 1.825V no matter what? It's a Shuttle AV18E 3.1 mobo...I haven't been able to find any documentation on the CPU supply or any limitations on it.
Before you ask, yes, I am sure I have the wire in the correct holes Any ideas?
Thanks for any help,
Ross
Ross
