Someone brought to my attention that I might be wrong to put both fittings on one side of the rad I have the alphacool nexxos x flow 360mm. There are no labeled ports on this rad take a look at this order and tell me if this is right or wrong please.
Thanks for all your replies so taking your guy's advice I changed my plan of attack Loop order is now pump to one side of the rad than from other side of rad, rad to cpu than cpu to gpu and finally gpu back to reservoir
Only think I would worry about is the line coming from the GPU into the CPU might be a little too long, and may kink on you when you fill it. Easy fix though.
