- Aug 10, 2010
- Sunshine State
I'm not saying it will hurt your computer... I'm saying that you're going to have a very hard time adjusting HT (FSB) with the given BIOS limitations.ok so your saying i should forget the whole fsb thing because its literally impossible to do for my computer, and because it might hurt my computer? explain :/
anyway could you tell me the benefits and downfalls of lowering my cpu multiplier. i just might go that route instead, if its worth it...
thanks for the help
There really wouldn't be any benefits from downclocking your CPU... They are built to run at their rated speeds and to last years and years doing it (provided there aren't defects).
If what you're after is longer "life" for your computer... You don't need to lower the CPU speed... You may want to look at maybe lowering the voltage that the motherboard is giving the CPU, but given that you're on a very limited BIOS; you may not be able to adjust that voltage.
I read some of your later replies and it seems to me you're a bit confused as to what you want... You mention "longer life" of your CPU... Just know that the longevity of your CPU is not related to the speed at which it runs... CPU life is dictated by two factors: Voltage and temperature... So as long as you keep the voltages within the "recommended" limits and do the same with the temperatures; your computer will live a long healthy life.
