I built my rig in 2007 and I'm not in the position to replace with a completely upgraded new one. However, my EVGA GeForce 8800 GTS failed on me so I need to get a new card. I figure I can at least get the best card that will help me with my current specs till I can afford to do a complete rebuild. I'm also concerned about getting something too robust till I do a full upgrade. So I'm worried about bottlenecking and basically getting too much card for what I have in my rig for now.
I need to know how I can get the best bang for my buck. Here's my full rig:
1) Windows XP (not ready to spend the $ on 7 yet)
2) Asus M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard
3) EVGA 640-P2-N821-AR GeForce 8800 GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Support Video Card (This is now dead)
4) AMD Athlon 64 FX-62 Windsor 2.8GHz Socket AM2 125W Dual-Core Processor ADAFX62CSBOX
5) ZALMAN CNPS 9700 NT 110mm 2 Ball Ultra Quiet CPU Cooler (Ultra-Quiet my a$$ - sounds like a rocket ship)
6) X2 - Corsair XMS2 1GB 240-Pin DDR2 SDRAM DDR2 675 (PC2 5400) Desktop Memory Model CM2X1024-5400C4
7) KINGWIN ABT-600CW 600W ATX 12V Ver.2.2 SLI Certified CrossFire Ready Modular Power Supply
8) Sunbeam Transformer IC-TR-SV Silver Steel ATX Full Tower Computer Case
9) I have two monitors so I need a card that will allow this.
So with my graphics card now toast and my budget on the thin side for the time being. I was told don't bother with a GTX 460 b/c of bottlenecking and I won't get much out of it on this rig. I'm looking at the Geforce GTS 250 1Gb (please note if you suggest something else though) but I have a number of questions:
Do I have a PSU (600w) to handle it?
Is my MB and CPU appropriate to fit anything that is suggested for a replacement?
IF there's another graphics card that will give me some better bang for mid-level buck expenditure, what might that be?
Should I get 2 more gig of Ram of what I've got or scrap that RAM and get 4G of something new? Does XP even see the extra RAM (meaning I just stay with the 2G I have right now)?
Can my case handle any of the suggestions or am I also looking at that as a replacement?
Any help or suggestions would be MOST appreciated. Thanks in advance!!!!!!!!!!!!!!
Mc1
Mc1
