- Nov 17, 2002
- Your Mama's House
I'm a wee bit confused about the whole set-up of my new system. The config. you see below is not up and running yet (waiting for my case and a RMA on my board...P4S8X's have big problems evidently) but I want to know if what I figured out needs any improvement. The case (Directron Dragon DX-01WD) will have two front lower fans, two rear mid fans, and the PSU fans. Also, the CPU HSF is a Dragon Orb 478. All the case fans are Sunon 80 mm 84.1 CFM.
The way I figured it is have the two front fans and PSU constantly going full throttle and have the two rear mids run off the mobo's temp. regulator, obtaining a positive pressure situation at low loads and a slightly negative system at high loads. Does it seem like overkill having a collective 168.2 CFM blowing and a slightly higher level blowing out? Are the four case fans even going work properly considering they will using 12VDC/9.1W each with two fans apiece connected to one 4 pin power connector? (Yeah, yeah...I'm a bit green here, but I just want to be sure. The power supply is rated for 525 watts and the yellow wire the fans use is rated at +12V/20A.)
I've tried looking for a review or comment on the Dragon Orb HSF I have but nothing is here. I should have probably gone with a separate HS and got a fifth Sunon 80 mm to run atop, but hindsight is 20/20. Is the Orb decent or not? Obviously I could of got better but with this hypothetical set-up is it alright?
Last question: I have no idea what type of airflow I will get, but how much improvement, if any, would a 120 mm side fan directed onto the mobo do? Would that screw with the dynamics of the case air flow having it blow onto the mobo while a hurricane of air is sucked into the case? Where is the best placement of this type of fan: over the Southbridge/expansion cards, the HSF, lower??
Any help would be great and appreciated...considering I'm in limbo while I wait for everything to finally get here (started ordering in late October ).
