- Oct 25, 2012
Well I recently found out what the ratling was inside my computer, it really sounded like a screw being loose but it's not. Two of my fans on my CPU coolers (both the same model, came with my case but were in the lower HDD bays, those bays being empty, didn't make sense to leave them there)
rattle like crazy at medium to full load (so I manual BIOS'ed them to run at 50 at all times)
Found this out by opening my case when the computer was on (yes yes I know its bad to do) Oddly enough this made the sound go away, (static pressure?) determined to find out I pressed up on one of the CPU coolers lower fans (=) <--- the bottom one if that makes sense in a push/pull and it rattled like crazy. The same with the identical model fan on the other CPU cooler. My two CM Hyper 212 EVO's run so the fans blow vertically, suck in from bottom push out top.
Obviously, running fans at only 50% on an overclocked machine is not optimal at all. I hear that using sleeve bearing fans in the vertical configuration as I've done is the cause of this rattling. (I don't know what bering type they are but... makes a lot of sense) What would you guys recommend for me to replace them with? I would like to overclock higher than 3.5GHz 24/7 one day, and I was thinking
http://www.frozencpu.com/products/1...n_-_5400_RPM_D1225C12BBAP-31_Coming_Soon.html
Which are double ball bearing. Are Gentle Typhoons still considered the best for CPU coolers/rads? Is there a cheaper, similarly performing option? I hear good things about Gelid...
