tatanka said:where can you get the carbon fiber vinyl covering stuff? I was thinkin of painting the interior of my case red but it'd be cool to paint it black now and cover the large area's with carbon fiber
Is_907 said:nice etching and great mod(s)!
i've never done any etching so i'm interested in how you got the colors? and just how it's done in general? (not detailed, just a quick summary =)
FarEast said:Great Mod......Those are great cases to work in !
Got the same case with the Silver trims rather than gold......As someone mentioned ...love the carbon fibre. on the CD rom.... But it might look even cooler if you put the same stuff on your front plate behind the plastic cover! I see you lost the top blow hole with the window though ! I'm going to build a top window but try and keep the fan mounts. Also to increase the airflow from the front two fans it's a good idea to remove the whole of the front panels and remove the fan guards. If you have a neon or UV inside you get a beter effect as well
What did you use to window the floppy drive ?
Xevuhtess7 said:if i got a smaller uv coldcathode (mabye 4 inches?), would it still make the uv paint just as bright as if i got a 12 inch one?
