freshy98 said:
The idea is nice and should be no problem to build.
Pump placement is a point of discussion since it won't fit in front of the heatercore/shroud/fan's combinations. There will be ducts an thus there is no place for the pump to be there as well.
The case is 220mm wide, so there will be plenty of space in front of the rads, and the pump is low profile enough to slip under fan exhaust path / whatever. On my schema the rads are up to scale but the pump is not
Anyway as i said there are plenty of options, and ducting would maybe mean putting the pump aside... I'll see that. But my first option is to open up holes in the opposite panel and put a light mesh, so air would enter from the left side (looking at front of the case) and exit directly from the right side.
freshy98 said:
My idea would be to place that right next to the heatercores instead of the fill/bleed system.
Yes that was my first idea as well. But that way the pump would flow directly to the waterblocks, and from the rads, and usually i prefer the opposite (pump -> rads -> waterblocks), but that's more a matter of taste. Anyway i try to use as few elbows / turns as possible, maybe that's being perfectionist
freshy98 said:
Personally I do not really like the bay reservoirs, so a something like
this would be a nice replacement for it. I do not like bay reservoirs because they simply do not fit the rest of the case. They are ugly!
Yes i was not too fond of bay reservoirs too, but that *clear* (not radioactive-green-like) double bayres, with the black case and general blue lighting, won't look too bad i suppose:
http://www.gruntville.com/reviews/wc/primochill_bayres/index.php
It's the one i placed on my schematics (double height).
Usually i tend to prefer round reservoirs as well, like this one:
http://www.xoxide.com/aneyefiblre.html
The Aquacomputer res is nice and well built indeed, but it's made of aluminium, which i want to avoid in my loop at all costs (100% copper). I even try to avoid brass by mostly using plastic barbs...
freshy98 said:
The place to build the reservoir I just linked could be placed best in the top of the case, about where the weird bar is. (on your picture the green line towards the fill/bleed system.
Yes the top of the case is roomy enough to put a round res anywhere. That's what i was planning first.. i may do that
The bayres is a nice option because of multiple barbs (less 'Y' splitters..) and very easy fill / air bleed solution, and requires absolutely zero cutting of the case
freshy98 said:
Btw: can't a reservoir be used to fill/bleed too? Also, for letting out air this would be the best place to have it as high as possible. (air goes up, not down).
yes yes yes ! The filling and air bleeding is supposed to take place in the bay res, which is at the highest point.
The lowest part i marked on my schematics is meant to *purge* the system.. i wouldnt want to put that monster of a case upside down.. I'm still thinking about it but it will be built like a very small airtrap, which will act as a small buffer, to prevent pump cavitation. Of course it will have to be mounted diretly on the pump inlet. With a hole on the bottom of the case it will be stealthy. If i don't go the airtrap/buffer route, i'll still have a purge system placed there
Put that on years of watercooling and experiences with a heavy, unforgiving YY cube....
(edit) the black case seems to be available on the 25th of June, or at least in Italy. Maybe it's the same elsewhere in Europe.
