- Dec 9, 2003
CordialSpam said:Anways I'm trying to push this thing up more to like a 2550...any clue what should I do to able to push this thing further? I tried raising the voltage and still doesn't work ..and I'm afraid of raising the vcore too much up...tried dimm volatege at 2.7..is it my memeory backing me off??
Don't do it. I backed mine to 2505 Mhz right now. I can run it at 2565 (285x9) pretty stable, but I have to feed it 1.65 volts. And at that speed my temps were 41/49 idle/load. But if I run it at 2505 (278x9), I only have to give it 1.55 volts and my temps drops to 32/37 idle/load. Yeah I know those temps are probably wrong, but relatively, a huge difference between the two speeds. I would much rather lose 60 Mhz so that I can run my CPU much cooler and at much less voltage. Furthermore, now I only have to give my RAM 2.8 volts rather then 2.9. So bottom line, I think the sweet spot for most of these midrange Newcastles is 2.5 Ghz. Good luck bud.
