- Jul 29, 2001
- Port Talbot, Wales
Hello all.
I want to change the standard fan on my ThermoEngine V60-4210 to a Delta 60mm Fan.
The delta fan comes with a 3 pin fitting to go into the mobo, but I've read that this is not recommend due to the current the fan pulls. copied from them:
NOTE: DUE TO THE HIGH CURRENT PRODUCED BY THIS FAN, YOU MUST USE A 3>4 PIN ADAPTOR. DO NOT PLUG DIRECTLY ONTO MOTHERBOARD.
Is this necessary? As this is only one place that I've seen this caution point, any one else agree?
Thx
Thx
