Short version: I want something that gives the best cooling performance for the cheapest price, at the cost of noise. The computer is in a furnace room, behind a wall of thick noise insulation. Even my R9 290X's stock cooler's fan at 100% is barely audible. It needs to be LGA1155. I'm thinking of the Noctua NH-D14, but I wonder if I wouldn't be paying premium just because it isn't a very noisy cooler.
Long version: I currently have a CoolIT ECO ALC (Single fan model) for my 2500K.
I was fine with it for years since I stopped playing games a long time ago.
I am planning to restart gaming and I am working on optimizing my current hardware (Replaced gfx card with a 290X).
My 2500K overclocks to 4.5ghz fin @ 1.38Vcore (peak) but the temps hover around 70-74 celsius (Prime95 small FTU) and I think there might be some throttling going on because some cores will perform much slower than others. At idle, it hovers around 38-42 celsius.
I tried re-pasting with fresh AS5 but the temps stayed the same.
I installed a second fan on the radiator (One fan on each side blowing in the same direction) but it doesn't help at all. I think the limitation is the heat absorbtion speed of the water block.
Now I don't mind buying a noisy cooler because the computer is in a furnace room, behind a wall of thick noise insulation. Even my R9 290X's stock cooler's fan at 100% is barely audible. Because of the case is out of sight, I removed the side panels and put a desk fan blowing into it, so there is no air flow issue with the case either.
Now, according to a review of my current cooler, I could shave off another 10 celsius with a Noctua NH-D14, but that cooler looks a bit expensive. Is there cheaper? As I said, it can be as noisy as heck, it won't matter to me.
