Oldtimer13
- Sep 10, 2012
- Albany NY
Hello , I have a AC converted into chiller that I have been working on for few month on and off. It finally about finished. My question is should I try to chill 3 video cards in your normal way, one after the next or should I try a 3 way split.
So every V-card is getting the same cooled liquid. I have already fabricated a 3-way split out of some copper tubing but the question really falls on if there will be enough pressure coming from the pump "Swiftech MCP655-B". So give me your guys options , ill be finishing up the CPU loop tonight. So i ll check back later.
